Browse Forums Owner Builder Forum 1 Aug 11, 2009 5:12 pm We never did mason work, but we want to make an l- shaped wall, about 1.40 high to cover up the outside laundry. (I think we'll get some of these DYO books at the library) The laundry is under cover. Which blocks do you recommend, with regards to the ease of work? We could maybe put the plumbing inside the wall. The surface should be OK without rendering. And where do you buy these blocks? I know that is not a real owner builder thing, less than a dog kennel... Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 5939 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10200 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61456 |
