Browse Forums Owner Builder Forum Re: prefab frame Qoute 5Aug 05, 2009 7:44 pm I reckon the quote is fairly good, when we shopped around before deciding to stick build it, the total was around the same, I think about 23000 and thats for a 36 square home. We tried Bowens TimberTruss Trusses plus and heaps others I just can't think of them now!! Re: prefab frame Qoute 7Aug 05, 2009 8:02 pm is that in normal pine or termite treated pine? It sounds in the ballpark anyway Re: prefab frame Qoute 8Aug 06, 2009 11:32 am Might just add when cross referencing quotes its important not to just look at the bottom line with trusses and frames. Things to look out for are: Stud spacings. Double top plate or single? Size of plates. Is ply brace included Is Valley board included. Beams that are included/excluded. Make sure that all the frames you want manufactured are included in the quote, some leave bulkheads etc out. Anyway just things to watch out for as the cheaper price may not necessarily be the cheaper price. This is 100% true. You can not hang anything on steel frames. very frustrating 8 7989 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28312 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4443 |
