Browse Forums Owner Builder Forum 1 Jun 26, 2009 6:15 pm The build has moved on pretty quickly this week. The red tongue floorboards took a day to put down on the ground floor trusses. Note the piles of walls waiting to be put up in the background - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then the walls started to go up very quickly indeed - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ By the end of the day all the ground floor walls were up except for a few minor ones. This is the view looking into the front door - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The house from the back garden - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The living room - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The dining room, with it's great view of the site toilet and the water tank! - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Grandad's downstairs bedroom suite - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The last two days the top floor trusses have been put on top of the walls. Note the floorboards for the top floor which were craned up today - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Next week - the top floor! JB Re: Walls! Walls! We have walls! 4Jun 26, 2009 11:04 pm Great progress, looks really good and solid! Building a Wisdom Prosperity 23 - http://erwisdomprosperity.blogspot.com/ Re: Walls! Walls! We have walls! 5Jun 26, 2009 11:11 pm excellent job!!! A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: Walls! Walls! We have walls! 6Jun 27, 2009 5:36 am hunts01 Fantastic to see JB, any reason you used red tongue instead of yellow, is there any benefit or major difference??? Cheers It's cheaper! Although it costs more per sheet, it can span 600mm joists rather than 450mm joists so you need less steel. I estimate I saved about $1500 by using red tongue. JB Re: Walls! Walls! We have walls! 7Jun 27, 2009 12:29 pm Looking good. How much is the steel installation costing you? Re: Walls! Walls! We have walls! 8Jun 28, 2009 9:53 pm Thanks JB, we have had our excavation done last week, 22 truck loads, it is amazing how much soild comes out. If you have time can you give the dimensions and price the red tongue was, the only reason i am asking is I am installing the sheeting myself and the yellow tongue is bloody heavy, i thought the red tongue might be a smaller sheet. Cheers Re: Walls! Walls! We have walls! 9Jun 29, 2009 2:20 am HI JB great work, my eyesights not too good, i can't tell if theres much weld around the beams or how frames r fastened (tech screws perhaps) anyway i'm probably telling u to suck eggs, but i'd make sure u get a few pots of cold gal or the like & spot over anywhere where metal is welded, screwed or drilled so all bare edges r coated. cheer tony Re: Walls! Walls! We have walls! 10Jun 29, 2009 7:01 am hunts01 Thanks JB, we have had our excavation done last week, 22 truck loads, it is amazing how much soild comes out. If you have time can you give the dimensions and price the red tongue was, the only reason i am asking is I am installing the sheeting myself and the yellow tongue is bloody heavy, i thought the red tongue might be a smaller sheet. Cheers The red tongue is heavier than yellow tongue, same size sheet but thicker. JB Re: Walls! Walls! We have walls! 11Jun 29, 2009 10:47 am That is looking excellent JB. Fantastic progress. Its very interesting looking at the steel footings and frames and comparing it to our wood ones. Do the steel frames fit neatly together? Or is there a degree of "massaging" needed? I know our wooden ones needed some talking to. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Walls! Walls! We have walls! 12Jun 29, 2009 11:28 am PeterH That is looking excellent JB. Fantastic progress. Its very interesting looking at the steel footings and frames and comparing it to our wood ones. Do the steel frames fit neatly together? Or is there a degree of "massaging" needed? I know our wooden ones needed some talking to. You can't massage steel Peter! All the walls have fitted together exactly so far except for 1 wall which is 5mm too big - currently sitting in the "too hard" pile! JB Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39717 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23401 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18065 |
