Browse Forums Owner Builder Forum Re: How much for an instantaneous gas hot water unit? 21Aug 02, 2009 9:43 am In the current OriginShop catalogue the advertised price for a Rinnai Infinity 26 is (with two controllers) $1299 whereas elgas has got the same but with one controller for $1135 Rinnai Envirosmart 24A with 2 controllers is $1599 at Origin and $1999 from Elgas. Re: How much for an instantaneous gas hot water unit? 22Aug 02, 2009 9:48 am Is Rinnai Envirosmart 24A smaller than Infinity 26 (since the number is smaller, or is this not how it works)? Re: How much for an instantaneous gas hot water unit? 23Aug 02, 2009 10:32 pm Hi, We are just looking at installing a new gas hot water heater and tossing up brands and instantaneous/continuous opposed to storage. I'm confused now. Also, I have read bad reviews of the Rinnai's Instantaneous - takes too long to heat up, need extra controllers to regulate temperature, temperature fluctuations, only get as hot as 46 degrees even tho they say 50 degrees and pressure related temperatures - has to be full pressure to get hot. It seems you only use the hot water tap for showers etc and dont use cold. This is ok for us but I am then worried about the kids using someone else's shower and thinking you only turn on the hot and will burn themselves. I havent found anything about the Rheem, negative or positive. Does anyone have any feedback? Sorry to butt in on your topic - not sure if this should go somewhere else but still interested in the pricing between the brands. cheers, Kym 1 week to go Re: How much for an instantaneous gas hot water unit? 24Aug 03, 2009 5:32 pm gettingThere Is Rinnai Envirosmart 24A smaller than Infinity 26 (since the number is smaller, or is this not how it works)? Read the tech specs, should be on the net. If it is anything like the Bosch units I was looking at the 26 will be 26L/min flow rate. I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14049 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
