Temp/permanent, why take it off? we also put spacing noggins in aswell, the more the merrya......
Ben
Browse Forums Owner Builder Forum Re: Top plate & frame centres? 21May 12, 2009 11:57 am Temp/permanent, why take it off? we also put spacing noggins in aswell, the more the merrya...... Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Re: Top plate & frame centres? 23May 12, 2009 8:09 pm Thanks guys, I had to think about the top hat part for a while, but I think I get it, it’s the zink metal battens that are referred to as top hat. I’m picking up a lot of great terminology from you guys and even if I don’t know what I’m talking about I will sound like I do. Thanks again to all. Regards KW......... “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8044 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31280 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3805 |
