Browse Forums Owner Builder Forum 1 Apr 24, 2009 7:09 am Hi there, We are at the stage of ordering our frames for what we consider to be a fairly large extenson, two bedroom, two bathroom downstairs with living upstairs. We have not as yet 100 per cent decided on cladding. Has anyone done any cost differences using Weathertex type weatherboard versus a foam system. Naturally with the Weathertex we would have to insulate. It is my uneducated opinion that having to use qualified tradesman to finish off the foam cladding would far outweigh the costs of DIY weatherboards. Also has anybody heard of washers et cetera pulling through the foam after some time and becoming visible? I would appreciate any input, thanks Cheeres Chez Re: Cladding dilemma 2Apr 24, 2009 1:15 pm philchez Hi there, We are at the stage of ordering our frames for what we consider to be a fairly large extenson, two bedroom, two bathroom downstairs with living upstairs. We have not as yet 100 per cent decided on cladding. Has anyone done any cost differences using Weathertex type weatherboard versus a foam system. Naturally with the Weathertex we would have to insulate. It is my uneducated opinion that having to use qualified tradesman to finish off the foam cladding would far outweigh the costs of DIY weatherboards. Also has anybody heard of washers et cetera pulling through the foam after some time and becoming visible? I would appreciate any input, thanks Cheeres Chez Foam cladding is supplied, installed and rendered for $95 - $105 per sqm, all the companies are much the same price. JB Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12062 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11122 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5652 |
