Browse Forums Owner Builder Forum 1 Apr 14, 2009 4:45 pm The roof plumber I'm talking to mentioned something about fire blanket in the roof of boundary walls. I've followed it up and apparently there needs to be at least 750mm length of a FRL 60/60/60 from the pitching beam upwards: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any suggestions/recommendations for a material and/or supplier ?? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Roof Fire Blanket?? 2Apr 14, 2009 4:47 pm kristofw The roof plumber I'm talking to mentioned something about fire blanket in the roof of boundary walls. I've followed it up and apparently there needs to be at least 750mm length of a FRL 60/60/60 from the pitching beam upwards: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any suggestions/recommendations for a material and/or supplier ?? Chris hi are you in bush fire area or is this all builds stay safe happy building Re: Roof Fire Blanket?? 3Apr 14, 2009 5:56 pm Hi Shelley, Quote: hi are you in bush fire area or is this all builds Nup, right in the middle of suburbia. Looks like it's for all builds though, according to the BCAs:http://www.bradfordinsulation.com.au/Regulations/BCAFire/Class1a.aspx Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Roof Fire Blanket?? 4Apr 14, 2009 6:09 pm ok thanks for the link im pretty sure but dont quote me lol that there are two types of foil wrap one for walls one for roofs the roof one has a better fire protection barrier so you cant use the wall foil on the roof.i know we have roof and wall blue foil wrap and thats all our roofer required so hope its enough stay safe happy building Re: Roof Fire Blanket?? 5Apr 14, 2009 10:47 pm Hi All, i haven't seen this requirement on any normal boundary setbacks in WA, where i have experienced it is in buildings that r built on the boundary or within a certain distance of the boundary ( i think under 1m- not sure) it certainly was never bought up when my plans were approved. cheers tony Re: Roof Fire Blanket?? 6Apr 15, 2009 9:38 am T&V Hi All, i haven't seen this requirement on any normal boundary setbacks in WA, where i have experienced it is in buildings that r built on the boundary or within a certain distance of the boundary ( i think under 1m- not sure) it certainly was never bought up when my plans were approved. cheers tony It is pretty common in WA. Its specifically required where you are building on or within 1 meter of a boundary to an adjoining property. The concept is that if your next door neighbours property goes on fire, this fire retatrdant blanket protects your property. Your roof lining alone wont stop a fire, but introducing this fire blanket will. Pat. We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5243 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3850 Not back peddling at all. You seem to have issues with comprehension my friend. Guy fcked up, he's considering being dishonest with his bank and hiding it. It will end… 21 14205 |
