Browse Forums Owner Builder Forum Re: Building a 40 square metre deck 13Feb 19, 2009 8:43 am You will find that the book is only good for decks < 1m above ground. There is other span tables applicable for decks> 1m above ground and depending on height, do your homework as you might find it better to put up brick piers as no need for cross bracing. No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6159 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 12885 |
