Browse Forums Owner Builder Forum 1 Dec 01, 2008 11:32 am Has anyone heard of Kool wall cladding?
It's a panel type system made of styerene with a fibreglass mesh. "The factory manufactured KOOL-WALL panel, incorporates the combination of EPS embedded with Fibre-Glass reinforcing mesh and sealed with a durable membrane coating." http://www.koolwall.com.au/koolwall/techprop.cfm Re: Kool Wall cladding 2Dec 03, 2008 8:43 pm Sounds like a styrofoam panel that is rendered over - stock standard really and from the installation details I can see nothing new or innovative about it whatsoever.
Happy to be proven wrong but my advice is to shop around as there are many styrofoam suppliers selling this stuff. You may even be better served by getting a solid plasterer/renderer to give a quote to supply and finish the whole lot (and get a guarantee!) Hope that helps a bit. Builders are people too.... Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4480 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12045 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11116 |
