Browse Forums Owner Builder Forum 1 Feb 28, 2024 10:03 pm Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer the concrete. Everything seemed fine until the concrete pouring began. Unexpectedly, there was a sudden leak in the stormwater pipe while they were levelling the concrete and didn't mention anything about leaks until I discovered myself when I got home. I am not a builder and have no experience at all. Unfortunately this is a bit stressful as I am unable to go to the next step of my Alfresco build. Clearly, the builder presented various excuses and requested that I find a plumber to address the issue without damaging the concrete. After consulting with several plumbers, it became evident that the fault lay with the concrete. What are my options? I still have the remaining payment. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 26788 2 6311 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 16379 |
