Browse Forums Owner Builder Forum Re: Bottom of Weep holes not 75mm above ground. 2Aug 12, 2021 1:56 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Bottom of Weep holes not 75mm above ground. 4Aug 13, 2021 7:13 pm Yep, the regs are 75mm in your area. Plenty of houses fail to meet the reg and provided the weep holes are not critically low, water doesn't pool against the house and drainage of the water once it is away from the house is good, it realistically shouldn't hinder a sale. The only remedy is to alter the finish level and that is usually pricey. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7075 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5423 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11145 |
