Browse Forums Owner Builder Forum 1 Aug 12, 2021 2:15 pm Our house was built more than 20 years ago. On the northern wall only, the bottom of some weep holes are above the pavers but less than 75mm. Our house is on the market and a building inspector engaged by a prospective buyer listed this as a structural "defect" in his report. What options do we have to rectify the matter. Await your comments, Regards Re: Bottom of Weep holes not 75mm above ground. 2Aug 12, 2021 2:56 pm Setanta On the northern wall only, the bottom of some weep holes are above the pavers but less than 75mm. It helps 'somewhat' if you post your region. The regulation isn't one all encompassing 75mm. Does your house slot into the 75mm category, do the pavers form an impermeable surface and does the surface slope away from the house? NCC-BCA V2 Class 1 & 10 3.3.5.8 Damp-proof course (b)The location of a damp-proof course or flashing serving as a damp-proof course, must be not less than— (i)150 mm above the adjacent ground level; or (ii)75 mm above the finished surface level of adjacent paved, concreted or landscaped areas that slope away from the wall; or (iii)50 mm above finished paved, concreted or landscaped areas complying with 3.1.3.3(b) (ii) and protected from the direct effects of the weather by a carport, verandah or the like; or (iv)in low rainfall intensity areas— (A)15 mm above finished paved, concreted or landscaped areas; or (B)0 mm above finished paved, concreted or landscaped areas if the damp-proof course is protected from the direct effects of the weather by a carport, verandah or the like. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Bottom of Weep holes not 75mm above ground. 4Aug 13, 2021 8:13 pm Yep, the regs are 75mm in your area. Plenty of houses fail to meet the reg and provided the weep holes are not critically low, water doesn't pool against the house and drainage of the water once it is away from the house is good, it realistically shouldn't hinder a sale. The only remedy is to alter the finish level and that is usually pricey. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 5076 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 4123 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 7982 |
