Browse Forums Owner Builder Forum Re: Does dilapidation report include site survey? 2Jul 18, 2021 12:07 pm In our experience, no. Dilapidation reports are typically done by people with building or engineering qualifications (our council will only accept dilap reports done by an engineer) whereas surveying requires different qualifications. If you also need a site survey then probably best to just contact a local surveyor separately. Re: Does dilapidation report include site survey? 3Jul 22, 2021 10:08 am Thanks for your reply! robw17 In our experience, no. Dilapidation reports are typically done by people with building or engineering qualifications (our council will only accept dilap reports done by an engineer) whereas surveying requires different qualifications. If you also need a site survey then probably best to just contact a local surveyor separately. Re: Does dilapidation report include site survey? 5Oct 06, 2021 7:39 am Dilapidation report is essentially existing conditions report on the building and site. I have done many prior to land redevelopment. It is to record existing conditions with photographic evidence to use in case dispute develops in relation to new cracking , building leaks and damage from construction on adjoining land. It is not a land survey, for that you will need a land surveyor. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog 4 6827 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223616 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7119 |
