Tilt Panel experts
Specifically - if you have a 3 story high panel design, doesn't the brace / prop that is holding the wall up, extend through the first and second floors, which would stop you from being able to complete those suspended floors to lock the walls in and remove the braces?
Or is there some other method where temporary cross bracing or Beams / wires across the structure under say the second floor or near the roof get installed to lock it, allowing the ground floor prop / brace removal so the first floor slab can get created and lock the bottom portion of wall together?
Or do they only do the panels a couple floors at a time, so the props are below the floor level that would lock the walls into place?
1
I totally agree with everything you have written. Thanks again for your always excellent input and advice. I really enjoy reading your posts cheers Simeon
