Browse Forums Owner Builder Forum 1 Sep 27, 2020 10:25 am Hi All I've been searching through the web for cable balustrade systems and there appears to be some simple, and some more complex options. My issue is that I have 5mm hot-dip gal posts and I'm desperately trying to avoid having to drill a million holes for all my cable saddles. It will take an eternity. I'm looking for a welding option where the cable end fittings can be welded to my steel post. Those saddles look too thin to weld. Does anyone have any ideas how to use a cable balustrade system with welding instead of screwing saddles to the steel posts? Re: Cable deck balustrade with steel posts 2Oct 23, 2020 8:06 am ![]() Hi All I've been searching through the web for cable balustrade systems and there appears to be some simple, and some more complex options. My issue is that I have 5mm hot-dip gal posts and I'm desperately trying to avoid having to drill a million holes for all my cable saddles. It will take an eternity. I'm looking for a welding option where the cable end fittings can be welded to my steel post. Those saddles look too thin to weld. Does anyone have any ideas how to use a cable balustrade system with welding instead of screwing saddles to the steel posts? This would give a professional looking finish. Use duralac on the eye bolt threads to minimise galvanic corrosion Re: Cable deck balustrade with steel posts 4Oct 23, 2020 8:37 pm ![]() use a nutsert, an internally threaded rivet and screw the stainless swagged wire in Betterhardware.com.au do a flip toggle where you can just drill a hole... Building Standards; Getting It Right! I suggest you use /provide proper certified details to the carpenter/builder Rather than rely on what he offers or tells you. That way you will avoid non compliance and… 3 1970 ![]() Revised plan has support where the bifolds meet in the corner. The posts are now 150mm and where I would like them. 150mm timber would look pretty cool, but I'm still… 6 2825 I would threaten them with dept of fair trading, you would have a good case especially as the images they supplied do not show uneven spacing. I didn't have to go that far… 3 698 |
