Browse Forums Owner Builder Forum Re: Owner Building Rammed Earth home in Jimboomba 21Oct 07, 2015 8:43 pm Giddie up!. Moving again. Good to hear. using Tapatalk Re: Owner Building Rammed Earth home in Jimboomba 25Oct 24, 2015 6:27 pm Looks good. I assume the shed walls and beams are in the foreground? Will be great to have some space for supplies and hardware. Are you going to move in whilst you build? using Tapatalk Re: Owner Building Rammed Earth home in Jimboomba 26Nov 18, 2015 7:07 pm So been a while, we've been having hassles with the shed company that is building our shed. But at last we have the construction started. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Roof should be going on tomorrow and shed is up. Ready to start getting organised with the stuff to build in a bathroom/line the walls, power for the site and shed, and general sewage/water Re: Owner Building Rammed Earth home in Jimboomba 27Nov 29, 2015 3:39 pm So shed is up and took a trailer load of cables and stuff out Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And spent this weekend doing up the rough in for my electrical, DB is mounted, and have insulation on order so hopfully next weekend will get the insulation started. Still have to batten the room for ceiling plaster then start putting up lining Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Building Rammed Earth home in Jimboomba 28Nov 29, 2015 4:50 pm Haha. Love the cot in the corner. Can't wait to see the fitout. using Tapatalk Re: Owner Building Rammed Earth home in Jimboomba 29Nov 30, 2015 12:00 pm Don't worry about the cot.....there's a Lucas Mill in there! Re: Owner Building Rammed Earth home in Jimboomba 31Dec 05, 2015 9:04 pm Shed is a workshop, and electrical is cheap comparatively, so i put in enough for anything i may wish to do, including 5x 3 phase outlets are going in along with the standard outlets. got most of the wall insulation in today Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Building Rammed Earth home in Jimboomba 32Dec 07, 2015 9:03 am Good to see you've insulated the walls. You'll be so glad that you've done that in years to come, even if the shed is only used as a workshop then. I'm assuming the roof was insulated after you took those photos too. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Building Rammed Earth home in Jimboomba 34Dec 12, 2015 5:42 pm Started putting up the battens for the ceiling. Taken a bit longer than expected, was aiming to have them all in today, however only made it half way before calling it for the day. Done 450 centers insulation bats to put in after we get the rest up. then on to lining. Does anyone know and decent suppliers for plasterboard? We've run a few and only one has gotten back with a quote, and the big green shed is at least $200 cheaper than their quote. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Owner Building Rammed Earth home in Jimboomba 35Dec 13, 2015 1:14 pm Have you tried Ornamental Cornice in the industrial estate at Logan Village yet ? Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Building Rammed Earth home in Jimboomba 36Dec 17, 2015 6:35 pm I'm looking to build in jimboomba septic tanks and water tanks have u found your supplier I'm thinking I will use Krystel Kleer they were so help full have u looked around yet Re: Owner Building Rammed Earth home in Jimboomba 37Dec 17, 2015 7:17 pm xxagray79xx I'm looking to build in jimboomba septic tanks and water tanks have u found your supplier I'm thinking I will use Krystel Kleer they were so help full have u looked around yet I got a taylex concrete tank for water, and for HSTP I got a worm farm treatment plant from wormfarm.com.au down in Hastings Victoria, yep from Victoria to Jimboomba. My hstp only needs inspection every 2 years, and because I'm on a sloping block, it uses zero electricity. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner Building Rammed Earth home in Jimboomba 38Dec 17, 2015 7:21 pm Taylex has taken a long time to get back to me with a quote I'm thinking Quality Tanks more ltrs and quote really quick Re: Owner Building Rammed Earth home in Jimboomba 39Dec 18, 2015 5:57 pm We are going with Quality Tanks although haven't got them in yet as we are still waiting for the firey's to burn the massive pile of trees right where the HSTP is going, They priced their ADV5000 HSTP and 2x 32,500Ltr with pump tanks for almost $4k cheaper than the nearest other quote we had. I have some cheaper prices for larger steel tanks however they are massive above ground tanks, vs the 90% underground concrete ones Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 25039 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4832 |
