![gettingThere](https://www.homeone.com.au/img/avatar_h1_25x25.png)
Just spoke to our plumber and I was right
![Smile :)](./images/smilies/icon_smile.gif)
He just wanted to make sure that we dont start on the footings until he's done his bit on the swer drain. YAY.
Browse Forums Owner Builder Forum Re: Can someone please talk me through the plumbing/slab stage? 21May 16, 2009 3:10 pm ![]() Do you think that maybe what he meant was just to make sure we dont make a start on the footings until he has sorted out his piping? :S Just spoke to our plumber and I was right ![]() He just wanted to make sure that we dont start on the footings until he's done his bit on the swer drain. YAY. Re: Can someone please talk me through the plumbing/slab stage? 22May 17, 2009 10:10 pm Nomad, I understand your point but the confusion here is simple. If Harkaway are building to lock up stage then they need to BUILD to lock up stage. What I am reading here is that Harkaway is simply a kit home supplier that is supplying materials only to lock up but leaving it to the owner builder to, well, build it to lock up stage. So, the question is - Who is the builder here? From what i have read it is clearly the owner and Harkaway are simply the supplier of goods but with a bit of advice on the side. While that is possibly a good thing it is clearly confusing for the Owner Builder. For example, Building Surveyors NEVER mark out boundaries - that is the job of a Land Surveyor. Again very confusing for most Owner Builders. So, to go back to the original questions: Are plumbers and electricians likelly to knock down the marks/pegs? Yes, absolutely Also does step 1 (cut) refer to excavation of the footings? No One of the plumbing quotes I've got says: It is a condition of this quotation that the sewer drain is laid through the garage BEFORE the excavation of any footings. What exactly does this mean? Basically they want to put the drainage in before the excavation of the slab or footings occurs. This is standard and common sense. The main issue here is to confirm that regardless of the depth of the sewer main that the plumber lays the sewer deep enough to be well out of the way of any slab beams or independent footings. The ONLY way that you will ascertain depth is from the engineer design read in conjunction with the soil test. If you are confused then PM me and I will give you my phone number so we can talk this through. Builders are people too.... Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 27060 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38935 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 19043 ![]() |
