Browse Forums Owner Builder Forum Owner build-Kareen Hills..Kitchen begins & decking complete 101Sep 14, 2012 9:10 pm Decking at front door now completed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen cabinets arrive on site and begin to go in...... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Work on kitchen continues tomorrow. More on our updated blog Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Owner build-Kareen Hills..kitchen begins & decking complete 102Sep 15, 2012 9:29 pm Island bench and overheads in now, stone bench tops, appliances and handles next Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills..kitchen begins & decking compl 103Sep 16, 2012 8:30 am Hi , I love your house. I think the polystyrene cladding is an awesome idea, are you able to tell me how it compares pricewise to brick or hebel cladding? I'm guessing the labour component would be significantly less than brick? Also I'm curious as to how you would go bolting things to the exterior walls ie clothesline, lights etc. Re: Owner build-Kareen Hills..kitchen begins & decking compl 104Sep 16, 2012 5:16 pm Hi Bayview. We had a long look at what cladding we would use, eventually settling on polystyrene. Compared to, Brick - Poly works out cheaper in cost, quicker to build with, with a higher insulation value. This means we did not have to insulate in the walls because of its high R value. The same with concrete blocks. Hebel - still cheaper than hebel and still quicker. The insulation difference is reduced greatly, as hebel is quite efficient, depending on the hebel method use use. ie blocks, the thickness will determine your R value, or panel. The panel is quick as well but you still need to insulate inside. As for speed, poly can be completed (panels, 2 layers base render, colour coat) in 4 days depending on house size of course. As for mounting things. This can be a problem you have to be aware of. Assuming a new build you must plan ahead and have plenty of trimmers in place for things you wish to mount. Not to mention long screws. They obviously have top be longer than the cladding with enough to go into the trimmer. Generally I use 150mm batten screws as the poly is 100mm. Normal outside lighting is not a problem as they are normally very light weight. The likes of a clothesline needs forethought and a trimmer placement. We found that this was the biggest disadvantage of poly that unless you plan ahead is is a bit more difficult. I found the easiest way around this problem is depending on what you wish to mount is simply to place a post, steel (can go smaller) or wood depending on application. So far there really hasn't been anything to cause any great concern. This was a brand new method of cladding for us and so far seems good and at this point, the insulation factor seems really good with the limited time we have experienced it. No doubt will post an update in time to come. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills..LOTS happening :) 105Sep 17, 2012 9:07 pm Lots happening in our final stage of finishing off ready for moving in. Front decking oiled. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Holland blinds installed, combo of block out and sun blinds....venetians too in bathrooms...forgot to take pics. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry cupboards in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plus study benchtop and drawers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kids bathroom vanity in, awaiting stone tops Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Began putting kitchen handles on Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Grass seed down out front...waiting on some green to appear. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Carpet going in tomorrow Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills..LOTS happening :) 106Sep 18, 2012 7:02 pm Looking great. Thanks for the info re poly. People look at me funny when I say I reckon my next house is gonna be made of foam. If you didn't tell anyone they wouldn't even know. But you would notice the difference inside, and in your hip pocket. And I like the rendered look so it's a cinch for me. One other question, does the poly screw straight onto the frame or is there some kind of battens underneath? Re: Re: Owner build-Kareen Hills..LOTS happening :) 107Sep 18, 2012 8:25 pm Hi Bayview Some people thought it weird when we first said we were having poly, but since seeing it everyone is impressed. It looks like normal render, only sounds a bit hollow if you happen to tap your knuckles on it. We and our tradies are amazed how well it sounds insulates. We've been there when the wind's been howling outside and you hear nothing. The company that clad us also said we won't need to run our air con/ heating much as it insulates so well....so looking forward to testing this out. The poly cladding doesn't need any battens, it gets screwed directly to the fame, after a breathable plastic membrane (not sisalation - it doesn't breath) is applied first. They use special long screws with a plastic basket/plate on the end.....here's a few pics to give you more of an idea. Our blog has more info too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Owner build-Kareen Hills...carpet install day!! 108Sep 19, 2012 9:33 pm Finally carpet installation day. H N's Smartstrand Silk Gentle Essence - 'Wildwood' on 11mm Cloud 9 Cumulus underlay. Really happy with the result....it's sooo soft!! Must commend HN Dandenong, for organising our carpet installation....the guys left home in Melbourne at 4.30AM to drive up here and install for us in a day.....great job!! More on our blog. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills..moved in finally - yay !! 109Oct 01, 2012 9:40 pm We moved in last Wednesday finally !! Haven't posted for a while. Busy times here. Alfresco area concrete poured, stone tops arrived for kitchen and bathroom vanity's, carpet and bamboo flooring installed. Will post more pics shortly..finally got rid of the rental today so now we can concentrate on the new house now Concrete pour Stone tops arriving Carpet and bamboo flooring going in. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...finally an update :) 110Feb 20, 2013 10:08 pm Finally got round to updating our blog. Been in and settled here for a few months now and really loving it here. Everything is working so well. Really happy with all our choices we made, from kitchen appliances, LED lighting, to aircon, solar HWS, carpet, bamboo flooring, landscaping, etc. Lots more on our updated blog. (temporary clothes line - shifting final one to a more inconspicuous location.) Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...finally an update :) 111Jun 14, 2013 5:54 pm Finally put our side fencing up. Now our doggies have a secure backyard. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...finally an update :) 112Jun 19, 2013 5:41 pm The outside of your house is looking great. I love the horizontal slat fencing, you've done a great job. edited to add - I just checked out your blog and saw your other photos. I love the photo of your 2 doggies sitting on the driveway. They are so cute. Our owner-builder journey - viewtopic.php?f=38&t=45187 Re: Owner build-Kareen Hills...finally an update :) 113Jun 22, 2013 8:15 pm TamK The outside of your house is looking great. I love the horizontal slat fencing, you've done a great job. edited to add - I just checked out your blog and saw your other photos. I love the photo of your 2 doggies sitting on the driveway. They are so cute. Thanks TamK Really enjoying the new front fences, slowing working on the garden beds in front of them now.... always plenty more to do Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...finally an update :) 114Jun 29, 2013 12:21 pm Finally got around to updating the blog with a few more pics if anyone's interested. Show's all the construction stages of our retaining wall, plus the new side fencing being built. Still lots to do.....but that's half the fun. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...blog updated retaining wall e 116Jul 04, 2013 9:45 pm DefenderOwner Looking Great!!! Thanks DefenderOwner Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...rear step & clothesline area 117Aug 03, 2013 7:57 pm Our new rear step into the alfresco area is now in place. Also our new clothes line area - complete with it's own retaining wall. All ready for planting out now. We decided to have clothes line set back into our embankment. A much better spot than our temporary one. Will be less obtrusive in our yard once plants are in place and our washing will receive full sun for most of the day. More pics on our updated blog. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Owner build-Kareen Hills...rear step & clothesline area 118Aug 06, 2013 11:49 am what a beautiful home! Well done. Re: Owner build-Kareen Hills...rear step & clothesline area 119Aug 10, 2013 10:24 am TinaG what a beautiful home! Well done. Thanks TinaG Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Owner build-Kareen Hills..slowly landscaping continues :) 120Dec 20, 2013 9:19 pm Slowly bit by bit we are planting out our 3/4 acre block....takes time and money....can't rush these things Hardy trees and shrubs finally in place at long last ...along the side fence lines. Retaining wall plants growing nicely, been adding more plants around the house yard ....step by step. New veggie garden up and running, with bird netting surrounding. Blog updated with more pic Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 14369 Yes, I was happy with the work, bar a few small things. Overall, communication could have been better though. However, I found them reliable and did good work at a… 4 63072 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 4243 |
