Browse Forums Owner Builder Forum 1 Jul 07, 2009 1:41 pm I've been searching everywhere on the net for a checklist of items that need to be done so that we can get a CFO. Does anyone know of such a checklist???? Cheers! Wendy The stumps are in the ground! Builder due back on site on 2 September 2009!! Building Due to start around the 1 August 2009 360 metre Driveway rocked and ready! Contracts Signed On 30 June 2009 Take one day at a time Re: Is there a Checklist for Certificate For Occupancy???? 3Jul 07, 2009 2:50 pm Sorry, I suppose I should've explained a bit further. We have the builders constructing the house on our farm just to lock-up (stumps, frame, cladding, roof and they should start about the 1st August. We then will be 'owner/builders' and employ the tradies to install other items such as plumbing, electrical, plastering, stairs etc. But we only want to know what the bare minimum is so that we are able to get a CFO so that we can end throwing our money out the window by renting and move into a 'worksite' instead! Eg: Just complete the main family bathroom upstairs and leave the ensuite and powder room incomplete downstairs. As I want a very 'expensive' kitchen (as hubby calls it ) we will purchase a kitchen out of the trading post just to install for the time being until hubby has earned more money for my 'expensive' kitchen . I've been told that some of the items you don't need for CFO are floor coverings/internal doors/plastering, but nobody has been able to tell me what I DO need and I really want to work out my budget so that I can make sure I've covered everything we need to get in to get CFO so that we can move in ASAP. I know that we need to employ a Building Surveyor that is able to check and issue the CFO and if we're missing things then he gives us a list that needs to be done before he can issue it. I just want to know all the items on that list that he's going to check to ensure that we have no time delays or budget blowouts! Wendy The stumps are in the ground! Builder due back on site on 2 September 2009!! Building Due to start around the 1 August 2009 360 metre Driveway rocked and ready! Contracts Signed On 30 June 2009 Take one day at a time Re: Is there a Checklist for Certificate For Occupancy???? 4Jul 07, 2009 2:55 pm hmmm makes a bit more sense. Lets work the other way what doesn't need to be finished. 1. As you said floor coverings in non wet areas. 2. Wall coverages away from wet areas. Like above sinks etc. 3. Heater and air cond dont need to be installed. 4. Perhaps doors etc. 5. Painting doesn't need to be on. Re: Is there a Checklist for Certificate For Occupancy???? 5Jul 07, 2009 3:03 pm This is a good place to start but is there no checklist out there? It's just all so confusing.... Would you consider a room that is 'planned' as an ensuite, has the plumbing pipes in place but no fixtures/fittings a wet area? What about the following items: Plaster? Lighting? Laundry trough? Insulation? oh.....I've just too confused as to why I can find any checklist... Wendy The stumps are in the ground! Builder due back on site on 2 September 2009!! Building Due to start around the 1 August 2009 360 metre Driveway rocked and ready! Contracts Signed On 30 June 2009 Take one day at a time Re: Is there a Checklist for Certificate For Occupancy???? 6Jul 07, 2009 3:22 pm best to speak to your survoyer. It is a bit for for a checklist in this case. ALso what you are doing is very hard. technically the house needs to be completed to what it says on the plan. Perhaps on the plan the ensuite should state future provisision for ensuite for example then you can leave it out. Re: Is there a Checklist for Certificate For Occupancy???? 7Nov 27, 2009 9:04 am Wendy, did you ever find a list? I'm in the same situation as you were right now. There are some things I'm concerned about not being finished - - decking (although the desk joists will be covered with temporary red tongue flooring) - steps up to the decks - laundry chute hasn't been fitted out and you can still see the frame inside the chute If you did find a "get-over-the-minimum-to-move-in" list for VIC I would be incredibly grateful. Thank you JB Re: Is there a Checklist for Certificate For Occupancy???? 8Nov 27, 2009 10:18 am Maybe you could also check with your local Council? I think they would also need to be satisfied that the house is "occupyable"? My signature is distracting people from my wise posts ... Re: Is there a Checklist for Certificate For Occupancy???? 9Nov 27, 2009 10:49 am I second above - ring your council, they should be able to email/fax what is covered. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Is there a Checklist for Certificate For Occupancy???? 10Nov 27, 2009 10:53 am The Certificate of Occupancy is issued by the building surveyor, so you would have to talk to then to ensure everything complies. Basically, you won't be able to move in right now as the following major items will have to be completed (off the top of my head - I may miss one or two things): - Electrical certificate (so you'll need all GPO's/smokies/light fittings fit off) - Plumbing certificate (roof plumbing, general plumbing such as sewer, stormwater and gas and plumbing for air conditioning) - Glazing certificate - Stairs and handrails to be compliant (and any other handrails that are required to the property). - Insulation would have to be in for compliance with your energy report - Tiling to wet areas, including splashbacks. - Termite protection (part a & b) if required. You would have to make sure your kitchen splashbacks are done also, even if it is temporary (including fire rating behind your cooktop if required). The plaster would have to be on. The electrician couldn't complete his fit off without it, and therefore couldn't issue his certificate. I'll add more if I think about any. Blog is now up - http://www.jbdave.blogspot.com/ Re: Is there a Checklist for Certificate For Occupancy???? 11Nov 27, 2009 11:01 am Quote: Wendy, did you ever find a list? I'm in the same situation as you were right now. There are some things I'm concerned about not being finished - - decking (although the desk joists will be covered with temporary red tongue flooring) - steps up to the decks - laundry chute hasn't been fitted out and you can still see the frame inside the chute If you did find a "get-over-the-minimum-to-move-in" list for VIC I would be incredibly grateful. Thank you JB The decking wouldn't matter usually, but in this case it would have to be finished as it has steps. The steps and handrail would have to be installed prior to C of O (if the fall is over 1 metre, so more than 5 steps or so). I doubt the luandry chute was cause any concern with the building surveyor. Blog is now up - http://www.jbdave.blogspot.com/ Re: Is there a Checklist for Certificate For Occupancy???? 12Nov 27, 2009 11:38 am jbdave Quote: Wendy, did you ever find a list? I'm in the same situation as you were right now. There are some things I'm concerned about not being finished - - decking (although the desk joists will be covered with temporary red tongue flooring) - steps up to the decks - laundry chute hasn't been fitted out and you can still see the frame inside the chute If you did find a "get-over-the-minimum-to-move-in" list for VIC I would be incredibly grateful. Thank you JB The decking wouldn't matter usually, but in this case it would have to be finished as it has steps. The steps and handrail would have to be installed prior to C of O (if the fall is over 1 metre, so more than 5 steps or so). I doubt the luandry chute was cause any concern with the building surveyor. Thanks mate, the decking is 700mm above ground level. Also there is a step up from the garage into the house of 250mm, do I have to put a step there as the step up is over 190mm? Thanks for your help JB Re: Is there a Checklist for Certificate For Occupancy???? 13Nov 27, 2009 12:28 pm Quote: Thanks mate, the decking is 700mm above ground level. Also there is a step up from the garage into the house of 250mm, do I have to put a step there as the step up is over 190mm? The decking I don't believe needs to be completed as it's under 1000mm high, so the fall hazard isn't there (therefore no handrail required). The step would have to be put in the garage because, as you said, it's over 190mm. Blog is now up - http://www.jbdave.blogspot.com/ Re: Is there a Checklist for Certificate For Occupancy???? 14Dec 28, 2009 1:55 pm jbdave has pretty much covered off all the paperwork requirements. - Electrical certificate (so you'll need all GPO's/smokies/light fittings fit off) - Plumbing certificate (roof plumbing, general plumbing such as sewer, stormwater and gas and plumbing for air conditioning) - Glazing certificate - Stairs and handrails to be compliant (and any other handrails that are required to the property). - Insulation would have to be in for compliance with your energy report - Tiling to wet areas, including splashbacks. - Termite protection (part a & b) if required. I would add to his list Vermon proofing / Certificate is required depending on state and local requirements Power & gas connection (this is not done automatically) Final building inspection certificate again the local council should be able to provide you with there requirements Re: Is there a Checklist for Certificate For Occupancy???? 15Jan 20, 2010 10:24 pm Shower screens, thats the only thing holding us up We have been in since christmas but haven't got shower screens and can't get the final progress payment until we get the certificate of occupancy. Who would have thought it would take over 5 weeks to get decent looking shower screens made Re: Is there a Checklist for Certificate For Occupancy???? 16Jan 21, 2010 7:55 am Also if you are in NSW then all the requirements of basix will need to be met before occupancy is granted. Andy Re: Is there a Checklist for Certificate For Occupancy???? 17Jan 22, 2010 1:55 am interesting thread we have been told by our surveyor we dont need plumbing or electrical we just need it to be verment proof and weather tight so basically walls roof floor power isnt required as people can live without it plumbing isnt required as technically you can use a portaloo one thing he did say was it had to meet all the 5 star ratings i know of others requiring heaps more but as were not at that stage yet i guess we will find out but i know one thing there is definately no list it seems like its up to your inspector and what he/she expects so id go have a chat with them some are very lenient (OURS) others not so much (TONYS) after all the inspector your using is the one whos going to issue you with the permit so get very friendly with them and ask gl stay safe happy building Re: Is there a Checklist for Certificate For Occupancy???? 18Jan 22, 2010 6:29 am Quote: we have been told by our surveyor we dont need plumbing or electrical ??? It's not about living with water and power, it's more about ensuring the house is compliant with all the relevant codes and standards. I guess you surveyor doesn't mind if your services are installed by un-licenced tradesmen ! Blog is now up - http://www.jbdave.blogspot.com/ Re: Is there a Checklist for Certificate For Occupancy???? 19Jan 22, 2010 7:43 am jbdave Quote: we have been told by our surveyor we dont need plumbing or electrical ??? It's not about living with water and power, it's more about ensuring the house is compliant with all the relevant codes and standards. I guess you surveyor doesn't mind if your services are installed by un-licenced tradesmen ! oh no all plumbing and electrical must be done by liscenced guys but not required for an occupancy certificate only when we want our completion certificate do we have to have electrical and plumbing done.two totally different certificates so we can still live there but will not be allowed to sell the house without the completion certificate. also u dont legally have to have power and water but if you do decide to have them only then do they have to be done by liscenced tradies stay safe happy building Re: Is there a Checklist for Certificate For Occupancy???? 20Jan 24, 2011 7:23 pm Just bumping this up as we are getting to the stage where we would LOVE to move in, sooner rather than later. I found this and it seems to be as close as you will get to a list - it is for Tassie - but I suspect it is relevant to most jurisdictions: http://www.meander.tas.gov.au/webdata/r ... FICATE.pdf We are in NSW and require 2 positive covenants to be placed on the property didnt really underdtand this but apparently it will take a few months, and have just been… 2 7816 0 6013 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 18279 |
