Browse Forums Owner Builder Forum Re: concrete slab has some honeycomb 3Jun 30, 2019 7:46 am Hi anthonysmythe100 Welcome to the forum The defect is called Concrete Honeycombing Was the Concrete inspected during the actual pour, do you have photos? Are there other spots visible? More info required It's always a good idea as an owner OB builder to understand your engineering Drawings/Details and Notes. Always inspect structural components, Take photos, keep records,ask questions, etc. Make sure you aren't taken advantage of by being an OB novice I would recommend that you check all Building Tolerances from here on as well Checking Wall and Floor Building Tolerances put the following trades on notice hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5160 yep, clearly mark where the infloor heating pipes are before drilling or nailing 1 6068 Building Standards; Getting It Right! is this for a residential dwelling or a shed? If its for a dwelling, its out of tolerance and a "mistakes happen" isnt a good enough excuse to just move on. 1 2433 |
