Browse Forums Owner Builder Forum 1 Aug 15, 2017 3:38 pm Hi Everyone! My name's John, I'm new here wasn't sure where else to ask, I hope you guys can help me. I was wondering if anyone knows how to find where cement render is on the floor plans? I know you can identify brick by the diagonal lines - is there a similar method for render? The render to the outside of the building was easy enough to spot on the elevations but there are a few spots inside that I can't identify. Thanks! Re: Reading the plans - cement render? 2Sep 26, 2017 1:25 pm No icecube2017, render is far too thin to be represented on a plan... even a 1:50 scale plan seldom done any more. Even the elevations can miss portions such as in recesses like porches, where in the good olde days, the draftsperson used to do a section to show these areas as well... not any more. Back-lining used to show that something solid was sectioned. Re: Reading the plans - cement render? 4Oct 31, 2017 5:03 am On this plan in North elevation, it's in a note with an arrow point to where it should be on the pier. Rendered Finished DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 10797 Thanks for that. I think the mortar has been sitting on these surfaces for approx a year. We’re at handover & they tried to get it off the rubber but have damaged it… 3 7233 DIY, Home Maintenance & Repair I do it all the time - units, mm/m, kpa/mpa etc and I still get on google and check it - it's easy to be out by a factor of 10, 100 etc 5 8717 |
