Browse Forums Eco Living Re: Rainwater tank issues 4Feb 11, 2018 6:21 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Rainwater tank issues 5Feb 11, 2018 7:37 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 7Feb 12, 2018 5:36 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 9Feb 13, 2018 10:57 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 11Feb 13, 2018 7:47 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Rainwater tank issues 13Feb 13, 2018 11:06 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 14Feb 15, 2018 1:33 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 16Feb 16, 2018 2:11 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 18Feb 16, 2018 10:52 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater tank issues 19Jun 29, 2018 5:00 pm To close this thread off...... In consultation with our builder, it was agreed that he would reduce the roof catchment being diverted to the tank to the northern roof area only (about 1/3 of what it had been). The charged underground system now has a screw cap in the storm water sump that can be removed to allow the system to be flushed. We have had a few torrential winter downpours since this modification and no tank over flows ! Yeehah!! Clearly the cost has been a reduction in the catchment and we will spend more often over the dryer months with an empty tank, but we are happy with the outcome that we have got to overall. Many thanks to SaveH2O for your valuable advice. Re: Rainwater tank issues 20Jul 16, 2020 9:20 pm My wife and I have just moved into a house with 3 x 3000 litre water tanks in Heathmont VIC, and almost zero knowledge of them. Almost all of this thread goes over my head. We had a plumber do some other work on a toilet and determined that 2 of the tanks are joined together, and feed the toilets and laundry via a pump and tank to main auto changeover switch, although the pump was unplugged when we got here. There is also a tap that appears to make the tanks feed the entire house, this was open, even though the pump was off. That tap is now off for the moment. Inlet filters on the top of each tank had a couple of cms of sludge plus a ton of leaves and other much. I have cleaned them and we are now using it for toilets and laundry, and looks/smells clean to the eye/nose. Can someone reccomend a tank specialist to come out and assess the entire system and give us some advice on it. We would be interested in if it can be used for showers and/or hot water and issues with that. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31286 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31169 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 |
