Browse Forums Eco Living 1 May 31, 2017 1:06 am Hi We recently had an aquaplate colorbond tank installed to replace an old galvanised tank for whole house water needs (no town water). A couple of days after it was installed we started noticing the water seemed to intermittently smell weird. Really hard to describe, kind of plasticy, but with a sweetish solvent type smell at times. Frustratingly we actually had a whole house filter system installed about 3 weeks prior (water was beautiful before the new tank). A small section of new pipe was put in (before the filter) at that time, but no new pipe at the time the new tank installed. So we dumped the water and got another load delivered, but again after it was in there a couple days the smell started again. Has anyone noticed this as "normal" for an aquaplate tank, and if so what type of filter do we need to filter it out? (Or what IS causing the smell?) Thanks for any insight at all! Re: Aquaplate tank water smells 2Apr 25, 2018 8:07 pm we've got 4 aquaplate tanks, and no issues with taste or smell... but we've never had water delivered, ours all comes from our own roof with 100L first flush diverters Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1672 |
