The brick has an R of 1.2 and a block has a R of ~0. But either one you use will need insulation. but building with blocks is a lot faster. What would you recommend? And for the insulation what will be better?
Thank you for your help.
Browse Forums Eco Living 1 Aug 13, 2008 11:10 am The brick has an R of 1.2 and a block has a R of ~0. But either one you use will need insulation. but building with blocks is a lot faster. What would you recommend? And for the insulation what will be better?
Thank you for your help. Re: Brick vs block 2Aug 13, 2008 1:12 pm Hi arthur,
Welcome to the forum. I'm not sure if you are talking about standard bricks, but that seems a little high to me. A friend sent me this table the other day, it might be useful. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As for what insulation to use there has been a bit of discussion on this... https://forum.homeone.com.au/viewtopic.p ... insulation I'm sure there is a lot more also if you do a search. Also the following is very good (it's where that table comes from) http://www.sustainability.vic.gov.au/re ... nefits.pdf Hope that helps btw, we will be using concrete blocks with R2.5 wall insulation (pink batts I think) 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ 6 11122 Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33654 4 4430 |
