Browse Forums Eco Living 1 Jul 04, 2015 4:49 pm Can anyone explain this to me? We are installing hydronic slab heating and powering it with an electric heat pump. We have been told you can also use the heat pump for your hot water. Is there a specific type of heat pump you need? A tank as well? Does this eliminate the need for a solar hot water service? Approximate cost? Regards, Limefroggy Re: Heat pump to power hydronic heating as well as hot water 2Jul 04, 2015 6:52 pm Hi limefroggy That is the set up we have. We have two heat pumps for our slab hydronic heating and our hot water system. We have a hot water storage tank. You won't need a separate solar hot water system as well. You could still install solar panels to off set the electricity used for the heat pumps. That is what we have done. We have Sanden Heat pumps which are 70%+ more energy efficient than your normal electric heaters. You won't be able to put your hot water system onto 'off-peak' electricity though, otherwise your floor won't heat during the day (if that makes sense). A company in Melbourne sized our complete system (calculated the thermal load I think it was called) based on number of people in the house and the design/ building materials of the house. They were fantastic. Bare in mind the 'two' lots of hot water don't meet. The in slab hydronic is a closed system. It is a 'heat exchange'. I'm still learning the process. So far so good, no complaints. The in slab is wonderful and the hot water is coming out of the taps Re: Heat pump to power hydronic heating as well as hot water 3Jul 04, 2015 7:02 pm Thanks dolphinblu, can you pm me the company you used? How much did it all cost? Regards, Limefroggy Re: Heat pump to power hydronic heating as well as hot water 4Sep 28, 2015 5:11 pm Hi dolphinblu, just jumping onto this older thread to ask who you used please? Re: Heat pump to power hydronic heating as well as hot water 5Oct 02, 2015 9:10 pm Justalittlebithippy- I just sent you a PM Re: Heat pump to power hydronic heating as well as hot water 6Oct 03, 2015 1:37 pm Using an integrated space heating and domestic hot water heating system is a good idea, especially if you leverage solar. If done well it is far more efficient and cost effective over its lifetime than two separate conventional systems. There's no reason why you can't have some thermal solar panels in series with the heat pump heating loop. The solar can pre-heat the water so you only need a smaller heat pump as the delta temp rise required of the heat pump with be much less (or maybe zero on a nice sunny day). If you use integrated PV-T (photovoltaic + thermal) panels, then you're doing even better (plus the PV component is more efficient than conventional PV only panels, as the fluid takes away some of the heat that reduces panel efficiency). Solar thermal is a far more efficient process than solar photovoltaic (around 3-4 times more efficient), plus the hot water storage tank is basically a big, dumb battery. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Heat pump to power hydronic heating as well as hot water 7Oct 03, 2015 2:59 pm Whilst I like the theory behind the PV+T panels I'd have some fairly big concerns. Domestic equipment is not known for being robust and the very cyclic loading you'd place on the panels would significantly reduce their lifespan. And water and DC never go well. My other thought would be the head the heatpump could generate. In an underfloor system you already have quite a high friction component so I'm not sure it would be able to cope with the run to and through the panels. Having said that if you could find a reliable PV+T (at a good price) that the system installer is comfortable with, that would be an excellent way to reduce the heatload on the heatpump and drastically reduce the running costs. Note you would also wamt to be able to isolate the solar heating section during summer as one of the benefits of the heat pump is you can pipe chilled water through the slab in summer. Using my LG-G4 to bring you this update. Re: Heat pump to power hydronic heating as well as hot water 8Oct 03, 2015 4:25 pm Finding suitable product with watermark approvals is difficult I must admit. Good products exist, but the problem is that traditionally Australia is a market that is very slow on the uptake of new technologies (VERY slow - one great analogy of that is the fact that in Germany they have museums about coal mines....we still have coal mines...). Companies like Alfa Laval have some excellent instantaneous heat exchanger products for space heating and domestic hot water (closed loop, open loop, and combination multi-circuit units). They are excellent units, but don't have AU approvals - the manufacturers don't want to spend the money going through the approval process because it is a risky market venture. They might spend $50,000 getting watermark, and sell 20 units a year... As for PV-T panels, there are a few around that I have no hesitation in using (and have used). Solimpeks is one. I have no concerns about safety (if buying from a quality manufacturer of course) with water running through PV panels. For example, we have been putting 240 and 415 volt heating elements inside hot water tanks all over the world for the best part of a century.... All good pretty much. Head pressure - I don't have proprietary knowledge of domestic hydronic heat pump units, if you're using a closed loop heat exchanger you'd just have a suitably sized pump to circulate the heating fluid through the closed loop. But if the circulating pump is part of the underfloor loop then yes, pressure drop may be an issue. I personally don't really do any engineering for domestic, but we are starting to do this sort of thing on a semi-regular basis when designing commercial and multi-residential buildings, hospitals, aged care etc. One example - I recently completed a 4 bedroom disabled care house/hostel where I designed ground source heat pump ducted AC, with the waste heat from the GSHP used to heat domestic hot water via a heat exchange tank. The overall build cost for this system was only about 10% more than an equivalent Daikin ducted VRF system and standalone Rheem solar/electric HWU - but is about twice as efficient. With the 5kWp PV solar system, the building is not far off being energy-neutral (except for basically lighting, power and cooking at night) Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Heat pump to power hydronic heating as well as hot water 9Oct 03, 2015 7:32 pm That would have been very cool to see the thermodynamic calcs for that and as you say perfectly viable (and I'd love to see more people using them) in domestic aplications. But we digress from the topic........ Using my LG-G4 to bring you this update. Re: Heat pump to power hydronic heating as well as hot water 10Oct 04, 2015 9:21 pm I wonder the ease & cost associated with having chilled water pumped through the floor in summer? Does anyone know what would be involved? Re: Heat pump to power hydronic heating as well as hot water 11Oct 05, 2015 7:09 am A heat pump works the same as an air conditioner in heat mode, so presuming that the heat pump can reverse its cycle like an air con does, it should be simple Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Heat pump to power hydronic heating as well as hot water 12Oct 05, 2015 4:11 pm Actually I just read where you said you have Sanden heat pumps. I believe these are solely heating units. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Heat pump to power hydronic heating as well as hot water 13Dec 11, 2015 12:54 pm have you heard of thermaskirt? www.thermaskirtaustralia.com.au I had it installed in my house after allot of debate and research into our options, Absolutely love it and glad we took the plunge! We went with the gas boiler, but we were also looking at the option of using a heat pump and think this could be a good option for people without mains gas supply. Showed it to my friends and clients, they are now having it installed. The good thing is that it can be retro fitted reasonably easily where underfloor is harder to retrofit. We have a large amount of floor to ceiling glass in our open plan living/dining/kitchen area giving us no options really for installing panel radiators anyway. We found that the ThermaSkirt still managed to keep the room cozy this last winter. They installed the ThermaSkirt under our kitchen units on the front of the kick board and we can't even tell it is there. We did come across a few negative comments when we were doing our research prior to go ahead with this option but found that most of this was down to incorrect installation. Due to this I would recommend that you look at getting it installed by someone who knows what they are doing. We used ThermaSkirt Australia who use their own installation teams and we were very happy with the outcome and finished product. Let me know if you would like me to post some pics of my house and I'll take a few for you. Hope this help Registered Building Practitioner DB-U 47858 CB-L 41119 email: segalandcoinfo@gmail.com https://sites.google.com/view/segalandco/home?authuser=0 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5118 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5017 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9147 |
