Browse Forums Eco Living 1 Mar 16, 2015 8:28 pm Hi all as the subject suggests are there provisions for a solar system that can be done by the builder when building a home? Is it worthwhile to do it through the builder or just do the whole lot after handover when money becomes available? Does solar panel generated energy change the power you would need connected to your house e.g. three phase? Re: Provisions for a solar system? 2Mar 16, 2015 9:46 pm I think the advantage of installation after the build is the panels will provide shading to your house roof helping keep it cooler in summer. Built in panels won't have this advantage and also run hotter which means lower efficiency. If I was planning to have panels installed I would Be going for a steel roof rather than easily damaged tiles. Making sure that things like kitchen extraction ducts weren't coming out of a roof that would be used for panels. Considering installing on West or East facing roofs (see http://www.anewhouse.com.au/2014/05/sol ... cing-roof/) rather than the traditional choice of North facing. And no you don't need any special power supply The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6481 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19516 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9793 |
