Browse Forums Eco Living Re: Which Solar HWS have you got? 21Feb 18, 2015 6:54 pm I'll try and find out some pricing tomorrow. PV-T panels with a storage tank and an electricity inverter should be cost comparable to a PV system and a solar HW system. Tractile is a complete roof system so you'd need to compare the cost of an entire roof system (battens and cladding), a solar PV system and a solar HW system. If you did that, the Tractile system probably would be significantly more expensive, but it is a very attractive aesthetic solution so you'd need to consider it in that context. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Which Solar HWS have you got? 22Feb 18, 2015 9:17 pm Thanks 1960sMH I'm interested in the solimpeks system as we have a colorbond roof just installed in our house being built. We were always intending to do solar pv after at some point and I wanted solar hw but a gas hw system was included so we went with it (instant gas hw was a $800 upgrade. I didn't think solar was worth asking about! ) Re: Which Solar HWS have you got? 23Feb 19, 2015 6:24 am You can probably keep your gas hot water with the solimpeks system. The PV-T panels would do most of the heating work, and the gas would be your storage tank and booster heat. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Which Solar HWS have you got? 24Apr 19, 2015 12:48 pm why do a lot of people turn their boost off in summer? if the water is hot enough its not going to boost anyway...? im getting a 315L 30 tube thurman (reece branded apricus) hopefully have it angled at 55° to maximise winter benefit and still work great in summer... would be interesting to see how much boost it uses for a year... Re: Which Solar HWS have you got? 25Jun 02, 2015 5:44 pm B-Man why do a lot of people turn their boost off in summer? if the water is hot enough its not going to boost anyway...? The other thing that can happen is this; - Your tank is heated all day from the sun - You use this hot water late at night for showers . - If you have the boost OFF, then your tank stays below maximum all night and then heats up again the next day . - If you have the boost ON, then your tank might heat up using electricity overnight and then the benefit of the next day's sun is lost as your tank is already hot from the boost. From my readings around the interwebs, it really does seem to depend on how your system is set up (as well as what sort of system you have installed). It also depends how your household uses hot water. A morning-shower family will have different requirements to a night-shower family. I'm about to get an Apricus 400L/40 tube, but I won't know for sure how it all goes until we move in and start using it later this year. Seksui KDR in Sydney (2015-2016) Links --> | H1 thread | Final plans | Timing of works updated 9/3/16 | Re: Which Solar HWS have you got? 27Jun 02, 2015 6:38 pm i have the chromagen system with two roof panels and 300 litre tank has a eternity 26 instantaneous gas heater the flow rate is very poor with the chromagen system in summer with 5 people household and teenagers that have now learnt the shower never runs out of hot water gas bill is almost nothing a solar system with gas booster i would highly reccomend but definitely a different brand Re: Which Solar HWS have you got? 28Jun 02, 2015 9:23 pm Old topic, but yes - if you have boost continuously left on, the water will boost overnight and you will get little or no benefit the next day from the sun. Just switch boosting off during summer (unless you run out of hot water) and turn back on when the temp drops or when you get some overcast days. I have a Thermann 22 evacuated tube solar hot water system with 250L ground mounted tank. Thermann is just a rebranded Apricus system. Works a treat, I still easily get enough hot water on overcast days, but I am in North qld where it doesnt get very cold! Dale - Building Newbie Proserpine, QLD Re: Which Solar HWS have you got? 29Jun 02, 2015 10:14 pm B-Man why do a lot of people turn their boost off in summer? if the water is hot enough its not going to boost anyway...? My Apricus 30 tube/315l tank have never had the boost turned on at all since we moved in here. Of course being in SE Qld, we haven't had extended periods of poor sunshine. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Which Solar HWS have you got? 30Jun 03, 2015 6:59 am I just leave my electric element on all the time and have adjusted the thermostat down to the minimum 60 degrees. I've monitored the energy usage over a week using a power analyser and it didn't switch on the whole time... that's in SE Qld and was a fairly mild sunny autumn week though Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 If so what were the "special circumstances" under which it was granted? "Note: If the development consent is for 'dual occupancy' an owner-builder permit can only be… 0 13985 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39262 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6456 |
