Browse Forums Eco Living Re: Rainwater Tank - Neat Power Cable Examples 2Jul 04, 2014 9:50 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Tank - Neat Power Cable Examples 4Jul 07, 2014 5:30 pm candycandy ...they look very modular. The (settling) tanks are probably 1 metre apart. Downpipes are not diverted, only the water. The overflow pipes are not connected (not needed) because the inflow stops when the tanks fill. The pump is about 4 metres away and everything is trenched. It confuses people because all they see is two tanks sitting there. candycandy I meant a neat cable example of a system already installed, so the power cable from the pump in the tank to the pump beside it and then into the external power point. You are describing a submersible pump and "the pump beside it" will no doubt be an automatic mains water switching device. Switching devices are not pumps but are often falsely described as pumps. A lot of these installations are unnecessarily messy as you have noticed. Submersible pumps are fitted to cut down on noise levels but an external pump in an insulated pump cover will make minimal noise. The submersible pump will also have a pipe coming out of the top of the tank and an electrical cable going into it. You can't do much about this unfortunately. The switching device can have a wall cover over it and many do. I have seen a stylish vertical wooden cabinet next to a tank that hid the switching device as well as provide shelves and space for a hose and other garden fittings. It's a good idea. Other common things you should look for... If you have any PVC pressure pipe exposed to UV, it is a requirement of AS/NZS2032 that it must be protected. This is a common area of non compliance that is not always picked up. Submersible pumps draw water through the bottom and most manufacturers state in their fitting instructions and warranty conditions that the pump must be installed above the sediment layer. Few are! Submersible pumps sitting on the tank's floor results in the pump vacuuming the floor, causing washing machine filters and cisterns to foul. It is also the reason that tanks fitted with submersible pumps are relatively clean inside. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31161 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19520 |
