Browse Forums Eco Living 1 Jan 27, 2014 4:48 pm Hi everyone, I found this on Ebay and wondered if you thought it was worth getting? http://www.ebay.com.au/itm/251435661931 ... 1555.l2649 Re: Worth it? “H2grO greywater” electric diverter irrigation 2Jan 27, 2014 5:19 pm Its a lot of money to pay for a "Last Resort System" (See this link to see why you should minimise the use of Grey Water in the Garden: http://www.anewhouse.com.au/2013/09/is- ... orthwhile/) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Worth it? “H2grO greywater” electric diverter irrigation 3Jan 28, 2014 10:30 am I have to agree Brian. I read that text you linked to ( I think I've read it before when I had a look at your excellent site a while back ). We considered a grey water recycling part to our upcoming build but the money you have to spend on a decent system isn't worth it in my opinion. We opted to go for just a bigger rainwater tank. We will however probably install the pipework for a GW system during the build but not connect it for a just in case scenario. The other thing to consider for a system like this is that I think any GW system is supposed to be inspected each year, incurring a fee ( health dept rules I read somewhere a while back ). Stewie Re: Worth it? “H2grO greywater” electric diverter irrigation 4Jan 28, 2014 11:02 am The only grey water that I use is the washing machine's final rinse. The 2 way diverter fitted to the 50 mm outside pipe didn't cost much (about 15 years ago), was easy to fit and the water is used on the garden in the immediate area. You have to use environmentally friendly products, Earth Choice does it for me. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worth it? “H2grO greywater” electric diverter irrigation 5Jan 28, 2014 12:41 pm I thought you just had to use a low phosphorous detergent but there are quite a few other things in the detergents used that are harmful to your plants and garden if using GW recycling... http://www.choice.com.au/reviews-and-te ... arden.aspx I think the secret is to just use the rinse water as Save H2O suggests. Stewie Re: Worth it? “H2grO greywater” electric diverter irrigation 6Jan 28, 2014 2:37 pm The link below is a survey and research report undertaken by the ATA (Alternative Technology Association) in conjunction with Associate Professor Barry Meehan and RMIT University's environmental Science Department that examined the impact of various bathroom products when used with grey water on the soil. http://www.ata.org.au/wp-content/upload ... _final.pdf The report is found on the ATA web site. http://www.ata.org.au/ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worth it? “H2grO greywater” electric diverter irrigation 7Feb 11, 2014 10:21 pm A good read SaveH2O.
I've often thought that the water from baths and showers would have the lowest impact especially where eco-friendly soaps and shampoos are used and would be ideal for greywater systems. Mostly because these two appliances use the largest amount of water for relatively little contamination ( if you've ever seen someone like my daughter take a twenty minute shower you'll know exactly what I mean ) ! We may be headed in this direction as well for our upcoming build after all. Edit : A couple of things that I thought worth mentioning in the pdf you linked to. "On the basis of this very limited sample there was some evidence that the ‘eco-friendly’ products were more harmful to the soils tested than the mainstream products. This is possibly due to the use of sodium chloride salt in many of these products." "There was no indication the so called ‘eco- friendly’ products were more suitable for greywater irrigation systems than mainstream products." Stewie Re: Worth it? “H2grO greywater” electric diverter irrigation 8Feb 11, 2014 11:45 pm Stewie, Are you going to OB? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worth it? “H2grO greywater” electric diverter irrigation 9Feb 12, 2014 8:11 am Yes. Plans all but completed ( don't laugh, we are up to Revision 35 ! I have done countless versions and 3D renders for my other half who has a bit of a problem relating 2D plans and elevations to the real thing ) and waiting on a few reports back from a geotech engineer. We need to finish the survey. The guy that does all my surveying did a quick one for me a few months back - just the levels but I want him to peg the two side boundaries. Then plans into the council which will be a 50:50 proposition to get through on the first go as there are a couple of things we are bending the rules on so we will see how that goes. Stewie Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20176 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 22749 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
