Browse Forums Eco Living Re: installation: hot water chilipepper, ecoverta and alike 2Mar 28, 2008 9:18 pm In an existing or new house?
Installation in new should only be minimal - depending on which one you go for. ie some need more pipes - some don't. There is a post in another thread here that mentions costs. Steve I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 1547 The time to heat is purely a function of the distance between the hws and the faucet. There are many options for hot water, you can also have a circulating circuit of hot… 1 4795 you can also look at fresh water chlorine generators. they still require salt, but it's 1200ppm or so, instead of 5500 for traditional salt water pools, or 2500-3000 for… 2 4966 |
