Browse Forums Eco Living Re: installation: hot water chilipepper, ecoverta and alike 2Mar 28, 2008 8:18 pm In an existing or new house?
Installation in new should only be minimal - depending on which one you go for. ie some need more pipes - some don't. There is a post in another thread here that mentions costs. Steve I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20734 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 15046 ![]() DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25214 |
