Browse Forums Eco Living 1 Aug 24, 2011 8:23 pm I was told today, and I don't know whether to believe it or not, that the argon gas inside double-glazing leaks out over time so that within ten to fifteen years your double-glazing will have lost all its argon gas filling. Does anyone know if there is any truth to this? Re: Does Argon gas leak from double-glazing? 2Aug 24, 2011 8:41 pm I've heard that it's about 1% per year. So even after 30 years it would have a decent amount left. It doesn't cost much more for argon filled and even if it only works for 20 years, it better than none. Having said that, I only got argon put into some windows that had a 8 mm air gap. You really need a 12 mm air gap, but 8 mm plus argon got me to the same as a 12 mm air gap. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Does Argon gas leak from double-glazing? 3Aug 24, 2011 11:19 pm A Swedish study (that I can't lay my hands on) showed that in windows leaving the factory, argon was at a concentration of 75%-90%, with 10% below 70%. Seepage was at a rate of 1% p.a.. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Does Argon gas leak from double-glazing? 5Aug 25, 2011 4:41 pm Liliana Thanks for the replies Casa2 and Ed. Is it possible to re-gas argon filled windows? Or is it not worth the bother? It's done in Europe, and maybe here by the time you need it.. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19241 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5082 |
