Browse Forums Eco Living Re: Heating question 2Jun 14, 2011 8:02 pm I don't know about petrol but in a house without gas....reverse cycle air conditioning was a lot cheaper than bottled gas. If I looking at a choice of under floor or panel I would go for panels. With underfloor you have to waste a lot of heat warming the slab before you start heating the room. Panels are also more controllable. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4889 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9963 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 |
