http://www.formatech.com.au/index.html
We're looking at building and husband likes the look of this product (he's a commercial builder who builds a lot with tilt panels). We'd probably render or clad the outside and are considering using it internally too for thermal mass and sound insulating where appropriate.
The company won't give a definite R rating as they say it depends upon what wall structure you decide upon.
Any comments?
Thanks.
Anyone know anything about Forma-Tech Wall Building System
To me it seems overly complex & messy for what it is trying to achieve.
An ICF solution seems preferable - simpler, better thermally & similar accoustic properties. Have a look at Zego, Formcraft, Thermacell, EcoBrick, Insulbrick.
Have a look at this guy who documented his ICF build in Australia: http://www.*.com/f176/icf-e ... ndex6.html
Also this USA based ICF discussion group is worth reading: http://www.greenbuildingtalk.com/Forums ... fault.aspx
http://www.greenenergybrick.com.au which took his fancy. Trouble is now we really need to make a decision and there is so much around and so many new products coming on to the market.
We saw these at a home show the year before last and DH liked them but then saw this: At 320mm wide though it'll take up too much space on our narrow block - even the Formcraft ICF we'll be using for most of the frame is 220mm wide.
As for SIPS that's another great option - we would have definitely considered it except that it has minimal accoustic blocking properties. Might still use it for the garage/loft. I saw them at the home building show last year but didn't take too much notice as I was hell-bent on ICF research. Also I remember at that point their website was terrible with limited info (now much better) & they only had some strange agency arrangement for Victoria - not sure if that has changed now.
We saw these at a home show the year before last and DH liked them but then saw this: http://www.greenenergybrick.com.au which took his fancy. Trouble is now we really need to make a decision and there is so much around and so many new products coming on to the market.
Will show DH, he is the one who knows all of this gobbly gook terminology! LOL
The only problem is that most other ICF systems have the foam on the inside of the mass rather than outside of it. To get the thermal advantage of having mass i.e. store heating energy - it ought to be on the inside of the insulation. It can't do that if there is interposing insulation
Sorry, you've lost me. Are you saying that there is better thermal mass if the concrete is on the inside of the insulation, in this case foam?
I was under the impression that in cool/temperate climates thermal mass was better on the inside and insulation on the outside. An exterior wall should be well insulated but thermal mass wasn't as important as on the inside where it is more so? Is this right? I obviously need to do Thermal Mass 101!
Thermal mass is the heat storage battery.
Solar radiation is the charging source,
You want the sun to pass through the window, enter the building, strike the mass and charge the battery. Radiation can also bounce around within the building to heat the mass but is most efficiently done directly.
At night time, when the sun sets and the indoor temp falls, the heat stored in the mass can be released to mitigate the heat loss.
To reduce the rate of heat loss, the entire structure should be insulated.
So the ideal combo for the external wall is INSIDE HOUSE - THERMAL MASS - INSULATION - OUTSIDE HOUSE. You don't need to have any mass in the external walls. You can keep it in the floor or the interior walls - but the same principle holds, the mass is WITHIN the insulation.
So the outer concrete walls of formatech are a bit of overkill as you don't need the thermal mass on the exterior walls? Although they are insulated you're paying for thermal mass in essentially the wrong place. Is that right?
But most ICFs are insulation:mass:insulation which makes the mass redundant thermally and the external cladding is not as durable.
Green energy bricks are just expensive.
Not sure what is the best product to build the walls out of.
Maybe look at sip.
Good Luck
Pulpo
I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I…
29/01/2024
5
The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it…
21/09/2023
2
Thanks for responding. Do you know of anyone installing this product in Sydney?
