Laying wooden floor over slab - ok thermally?
I'm sure I read on here a while ago that you could lay a floating floor over the slab without it affecting the heat transfer between the thermal mass and the inside surrounds so long as it was X mm above the slab but I cannot find that now.
Can anyone confirm or deny this for me?
TIA
Unless it is a waffle slab, as they are insulated from the earths conductive(?) heat and will be more inclined to fluctuate with the daily average temp...IMHO only
Aside - any covering that blocks the direct sunlight will act as an insulator to impede 'Gain' and reduce output
... rubber tile adhesive is an ideal insulator so not good for heat transfer into the slab.
FWIW I prefer just concrete
But does use 3phase power.. though they are at most deli's
in the form of gesets
I am with Onc, concrete floors are my floor of choice. alas i am whipped, my wife isnt a fan, so we have timber.
my foot will be firmly down in my next house, and we will have polished concrete floors and Onc will be polishing my waffle pod slab.
Looks like I have to find a tile glue that is less insulating than most
We have a mix of slate, polished concrete and a few bedrooms are carpeted
In the morning the 'hard' floors feel cold, by 8.30 the sun has begun its cycle and they are no longer cold
There are a LOT of trees around the cottage and so solar gain is minimal but definitely felt
I don't like carpet because it is never clean after the day installed and being a pet lover easy clean is a priority for us... when the furries come to visit, 2 mins will recover all ills.
We are lucky that with 100 acres we've been able to site the house more or less where we want, there are no trees to shade any of the slab and we can orient to true north, though have gone a few degrees off to maximise the view.
Of course when we win lotto prior to having to lay these fixings I can change my mind and go for a coloured screed with a lovely design and plenty of luxurious persian rugs to cover in winter
But I have no idea about the design you have chosen...
aside - I can't believe people are still polishing concrete using water, what a waste and a mess.
As for the water polishing, maybe that's what you get in the bush for these fang-dangled big city ideas
ETA would be interested in your thoughts on the carpet issue for the master if you look at the design. I'm having a 'conversation' with DH about making the one of the walls an internal brick to help with the solar gain to the slab issue if we go carpet.
7
Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should…
14/03/2024
6
Old Home Restoration / Renovation
To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,…
20/04/2024
One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the…
