Browse Forums Eco Living Re: Brisbane solar power recommendations please 2May 02, 2011 1:10 am If I was to win Lotto, I would build with a different builder, now to win lotto Re: Brisbane solar power recommendations please 4May 06, 2011 2:14 pm I would of thought it would not of mattered because I would expect it to be the same as if it was dark, no power going from the panels. TBH I can't remember what order they said to switch things off, if needed I was going to use the big red sign in the switchboard (at work so can't read it atm) If I was to win Lotto, I would build with a different builder, now to win lotto Re: Brisbane solar power recommendations please 5May 08, 2011 2:50 am Like you I cant see the difference if there is a power failure. I'm just checking as I was told by my solar electrician to shut off the isolator on the switchboard first, as doing it last would cause the inverter isolator to break-down (and need replacing) after about 10 times. Might check with the folk at Whirlpool. Arfur Re: Brisbane solar power recommendations please 6May 19, 2011 1:00 pm Just had a 2KW system installed with solarsolar (www.solarsolar.com.au). They have been fantastic. Dealt with a real honest, down to earth, cheery bloke. He was completely up front with all costs and was happy to chat about the options I had. I went with the more expensive REC panels and Xantrex inverted (as opposed to the cheap chinese stuff) and I'm happy so far! So yep! Solar Solar. Give them a go Building at Warner Lakes in sunny Queensland. Building with Bold Properties. Building thread is here! - https://forum.homeone.com.au/viewtopic.php?f=31&t=38957 Blog is here! - http://campoutforland.blogspot.com Re: Brisbane solar power recommendations please 8May 07, 2013 5:21 pm Sorry to hear of your misfortune. If you havent already I suggest you post your complaint on Whirlpool in the Green Tech forum to warn others Arfur Re: Brisbane solar power recommendations please 9May 13, 2013 10:27 am The system was ordered 5th March, it is now 13th May and it would appear it was finally up and running last week. Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8568 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14228 2 15465 |
