Browse Forums Eco Living Re: Reducing Energy - Home Theatre 8Jan 05, 2008 5:37 pm Cb and CDN - all good points and unless you know ALL the costs and outputs to buld the new item - it's a tough one to objectivlty anwer - other than I'm with you - use it till it's uneconomical to continue using - or the GH outputs are offset - long term.
But the main point here is dynamictiger is installing Solar Panels - so needs to cut the load and also accuratly work out his actual current draw. An easy way to do it to buy one of these. And if you join the Alternative Technology Association and you can rent one for a week. http://shop.ata.org.au/cart.php?target=product&product_id=16354&category_id=322 Another way is to use a digital mulit-metre - but unless you know what you are doing - don't do it that way. Steve go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110527 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16252 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10621 |
