Browse Forums Eco Living 1 Mar 15, 2011 12:46 pm I live in a three storey house with a roof-top deck. Our only small north facing roof is effectively the fourth storey. We are a two person household and likely to stay that way for some time. We currently have an off-peak electric hot water system (no outdoor area for gas system). Below is what I was quoted to convert to an Apricus evacuated tube electric boosted solar hot water (noting a bit of a tricky job given the height). Would this cost make it economically unviable over 10 years, i.e. outlay greater than savings within warranty period? Does the quote look to be in the ballpark or is it high? Any advice would be appreciated. Regards JT Inner suburbs Melbourne Quote: Both systems qualify for three rebates when changing from electric to electric solar. STC’s, VEEC’s and Federal rebate. Option 1: 250 litre Vitreous enamel tank with a 3.6kw bottom element and 22 Evacuated tubes. Option 2: 315 litre Vitreous enamel tank with a 3.6kw bottom element and 30 Evacuated tubes. The frame for the tubes would come past the side of the North facing roof above the stairwell. Option 1: Length – 1980mm, Width – 1700mm. Option 2: Length – 1980mm, Width – 2200mm. Price includes: Drain and take away the old tank. Install new tank on the other side of the wall. Alter hot and cold pipes onto the new tank. Alter power to the new unit. Install new tank in a safe tray with terminator valve. Install power point for solar pump. Install frame and tubes on the North facing roof above the stairwell Flow and return from the tubes to the tank in copper with Armaflex insulation. Flow and return run on the East outside wall. Colourbond capping over the flow and return. Sensor wire from the tubes to the solar pump. All valves to regulation. Solar tempering valve. ( 50 deg) Certificate of compliance. Certificate of electrical safety. Cherry picker for access from the back lane to run the flow and return. Commissioning of the system. Notes: STC’s (formally REC’s) and VEEC’s to be claimed by HWP. Federal rebate to be claimed by the owner. We can provide the forms. All work would be completed in one day. Acceptance of the quote can be by fax or email. Payment options are cash, cheque, credit card (2% charge) or EFT. Option 1: 250VE/22T Total = $9,075.00 Less STC’s – 22 X $32.00 = $704.00 Less VEEC’s – 24 x $7.00 = $168.00 Total on the day = $8,203.00 Less Federal rebate = $1,000.00 Total after all rebates = $7,203.00 Inc GST. Option 2: 315VE/30T Total = $9,790.00 Less STC’s – 25 x $32.00 = $800.00 Less VEEC’s – 26 x $7.00 = $182.00 Total on the day = $8,808.00 Less Federal rebate = $1,000.00 Total after all rebates = $7,808.00 Inc GST hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20902 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14306 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12382 |
