Browse Forums Eco Living Re: Green Roof 3Jul 21, 2010 2:56 am I am thinking of ripping the roof down, its got a design fault that is dragging the center wall out into a hallway. The thing is hardwood stick build and the support is overloaded, the whole north face is bowing down and inward. (the house was hand built in the 40's.) Any ideas on how much it would cost to have this demolished so I can replace it with an LVL truss on a flat roof profile? I only need demolition and a the center hallway frame constructed to at least hold canvass up. Is it permissible to build an extended wall to hall this up, as an extension on what already exists? I am thinking of raising it enough for a crawl space under the truss and decking it American style with ply form flooring panels, toung and groove sealed with liner, toped with 50mm foam panel and then sealed again with liner, drain and geo textile finishing with growing media. Just wondering how to go about it... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ^^ This is a roof full of succulents on a court house.. If it costs 10k then so be it. I don't really have a choice, the roof frame at the rear is done for and holding tiles ATM. The green roof would provide thermal protection in summer like nothing else so I would rather pay 10,000k now than feed AGL with Air Con bills. Re: Green Roof 5Jul 21, 2010 6:11 pm Its fairly easy to install and maintain. THe hardest part is getting dumbass council to approve the design given its not standard materials, tile, metal. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just thinking of using a truss system to span the roof no different to what you would if you were adding a second story only it needs to be stronger, not much of an incline. Needs to be strong for weight gain during storms. Most of the water will be held within the media until saturation. The discharge is filtered but can take up to 10 minutes to arrive at the down pipe. I imagine by using more trusses I can mitigate the stresses. Once its tied in with flooring ply (30mm) the thing will be so solid you could park a bus on it. I really seem to get the feeling this is stronger and cheaper then replacing the roof with Colourbond, mostly I can do this myself. I just need a builder to guide me through the stages and set the things up right. http://greenroofs.wordpress.com/ http://www.fytogreen.com.au/products/ro ... index.html http://www.elmich.com.au/greenroofsystems/about.php Some inspiration. http://greenroofs.wordpress.com/contact-us/ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The benefits are no noise, I have aircraft for Tulla landing in this direction, It also insulates perfectly on blasting hot days, plants / succulents / grasses stay nice and cool, the media transpires and the underlying material is far cooler then the air. It also allows me to place solar equipment on the roof which I can't do ATM because the roof is not up to it. 2 9450 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4214 |
