Browse Forums Eco Living 1 May 15, 2010 7:18 pm I would greatly appreciate any information on solar hot water systems. . Our builder has advised that the system we will be recieiving is a Rheem Solar Loline tank 270ltr 3.6kw with 2 x NPT200 collector. The 2 panels will be installed on a north facing roof. The little information I have read does not rate this system very well as being efficient or reliable. Does anyone have any information on this? Are there any better options? Are the tubes better than the panels? Any information would be greatly appreciated. Building a modified Allcastle home Re: Help required with choosing a solar hot water system 2May 15, 2010 7:24 pm Hi fabricgirl, I'll be interested in any responses you get. We are having a Rinnai 5 star continuous 315 Solar (electric boosted)unit with 2 solar panes. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1662 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
