Browse Forums Eco Living Re: New Build - Energy efficiency upgrade on limited budget 21Jun 23, 2010 8:46 am An island bench is not essential in the kitchen for me. While I do love island benches, it is not a high priority. My priorities in the kitchen are that there is enough usable bench space as well as a huge walk in pantry (being shorter I find it difficult to reach items in the top shelf of overhead cupboards, so prefer a large walk in pantry where items are easier to reach). Thanks for your suggestions, I will definitely consider implementing them. House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: New Build - Energy efficiency upgrade on limited budget 22Jun 25, 2010 12:33 pm Just a few addition suggestions: You will find it a struggle to fit R2.2 batts in the walls as R2 is bordering the limit for 90mm studs. R4 in ceiling and R2 in walls is plenty, R3.5 and R1.5 are plenty sufficient most of the time but I always recommend the R4 and R2 as it is not much more $$. You will not overheat the house in winter with double glazing, the worst case scenario you will have to open a window for 20 mins, research the upgrade to double glazing before you buy the windows, get a quote for both types of windows. Also you should be inspecting the work of the insulation installers to see if they are not leaving any gaps in their work or taking shortcuts. Also make sure all your windows are weather sealed when installed in the frame. these little things make the biggest difference. Re: New Build - Energy efficiency upgrade on limited budget 23Jul 02, 2010 2:15 am Michelle, you are going to need all that insulation. Did you see it got down to -5 the other day? go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110524 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3473 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17518 |
