Browse Forums Eco Living 1 Jan 14, 2010 12:15 pm Looking into this product to use as our means of an underground water tank. The bagel type works out to be around $8k per unit (5000lt) This works out to be around $8k for a storage capacity of around 20,000lt. www.ecowaterboxx.com.au Thoughts please would be appreciated. Dirk Re: Anyone used Ecowaterbox? 2Aug 07, 2010 5:20 pm Hi Dirkadirk Did you end up going with this system? I don't quite understand your pricing is it $8000 for 5000 litres or $8000 for 200,000 litres? I would like between 7500 and 10000 litres and looking for price. Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: Anyone used Ecowaterbox? 3Aug 08, 2010 6:05 pm 71monaro Hi Dirkadirk Did you end up going with this system? I don't quite understand your pricing is it $8000 for 5000 litres or $8000 for 200,000 litres? I would like between 7500 and 10000 litres and looking for price. Hi 71monaro, No we didn't go with this system as all the engineering had been done and I guess it would have cost another small fortune to redesign the slab to accommodate this type of tank system. The costings are correct, as in it would have cost around $8000 for a 200,000 litre capacity storage arrangement. On top of that you would have to pay for excavations and removal of excess soil too though. I ended up going for a 9000lt tank that will sit under the deck area to the rear of the house, so it still wont be seen. Cost me $1500 for the tank. As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17864 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 24824 |
