Browse Forums Eco Living Re: Solar hot water boost 21Mar 20, 2010 7:27 am I like hot showers so not coping well with this whole tempered hot water thing. I'm finding we have to have the boost on all the time to keep it hot enuf and still i have full hot..no cold. It's pretty awful for washing up..find the grease on pans much harder to get off Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Solar hot water boost 22Mar 20, 2010 10:42 am Hot water takes 10 min to burn at 49 degrees and 1 sec at 60 degrees. Tempering valves mixes in cold water from the system to bring it down to 50. It is a safety thing. Re: Solar hot water boost 23Apr 11, 2010 8:58 am My understanding is that tempered water only has to be used in sanitry fittings not all outlets such as kitchen sins. "AS 3500.4 With reference to Clause 1.10.2, Part B, all new hot water installations, shall deliver not water not exceeding 50°C in residential buildings, at the outlet of all sanitary fixtures used primarily for personal hygiene purposes. The Clause is obviously referring to baths, showers, and hand basins in a bathroom or ensuite." If you are building you can have 60 degree water at the kitchen and laundry but not the bath or ensuite. As stated by others storage of hot water should be above 55 degrees (60 nominally) to reduce legionella risk. Legionella is present in most water supplys and proliferated between about 30 and 45 degrees, with the top of this range being most peoples ideal shower tempersture. I have been involved in the testing of hot water supplies in a health facilitiy and over 5 years we have never had a positive count from instant hot water services but have had them from storage units on a number of sites. My personal thoughts on this is that instant units heat are required and the system is flushed with each use so there is not storage where proliferation can occur. I would go instant hot water services if they can be located close to point of use but this may require more than one unit on a large house the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14071 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20234 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
