Browse Forums Eco Living 1 May 20, 2009 5:17 pm Does anyone have the inside scoop with regard to the QLD rebate? I have expressed my interest via the 1800 line but now my electric HWS is facing a slow death. We can't even finish a shower with hot water. I haven't had any correspondence with regard to the rebate yet? I don't want to rush out and replace it with a new Solar set-up immediately as I believe Anna's rebate may mean only $500 out of pocket. Currently I have quotes for $3800 (split) and $3100, not accounting for the $1600 from Kev. I'm thinking maybe I get a service-man to have a look at the current electric HWS and see if we can get more out of it before replacing? Whatta ya reckon? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14165 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20312 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24260 |
