Browse Forums Eco Living Re: Which Solar Hot Water System do you have? 21Jun 14, 2013 10:44 pm had a chance to ask hubby. He said he thinks edwards bought out solahart. it was the heating element. you need to get an element that is tin plated for hard water rather than the standard element . Depends on where you are though. In some parts of the SW the standard element is fine. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13564 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
