Browse Forums Eco Living 1 Jan 07, 2009 11:10 am How much does it cost to install a slimline 2000 lts rain water tank connected to down pipes. I don't want to connect it to toilet - just want to use it for garden plants so need a tap only.
Is it easy to DIY if there is a concrete pod already made to place it on? How to divert the down pipes into it? Are there any govt rebates for purchasing these tanks? Our Entertainer - http://ausdreamhome.blogspot.com/ Re: Rain water tank 2Mar 13, 2009 2:46 am It doesn't sound so easy to me if you DIY... consult a professional before doing.. just an advice from my side to avoid future complecations Jack Nelson Re: Rain water tank 3Mar 13, 2009 8:12 am If you are going to DIY, don't forget that you need to connect the overflow to the storm water for when (if??) it is full and over flows.
When I get my tank, I will probably do the concrete slab bit myself (or get my BIL to help me with it) and then get a plumber to do the rest 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Rain water tank 4Mar 13, 2009 9:35 am For a slimline tank if is made of poly I think you can just put it on a sand pad... Plumbing is easy to a pump and that's it... If you are half handy and confident with cutting guttering downpipe & storm water pipe then go for it.
Rememer to: Cover pump from rain etc. Run electricity to pump Plumb overflow into stormwater Re: Rain water tank 5Mar 13, 2009 6:16 pm For watering the garden you may consider the gravity fed outlet.
You may consider putting the tank on a stand, to raise it (it would simplify downpipe plumbing too) and increase the gravity pressure and so save on the pump and electricity connection. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Rain water tank 6Mar 18, 2009 4:53 pm satskape How much does it cost to install a slimline 2000 lts rain water tank connected to down pipes. I don't want to connect it to toilet - just want to use it for garden plants so need a tap only. Is it easy to DIY if there is a concrete pod already made to place it on? How to divert the down pipes into it? Are there any govt rebates for purchasing these tanks? My builder just quoted a slimline 2500 litre tank connected to the wc for approx $3700. I have no idea whether the quote is reasonable, but I will check with a few local first before giving the go-ahead for the cost. Re: Rain water tank 7Mar 18, 2009 5:15 pm Quote: My builder just quoted a slimline 2500 litre tank connected to the wc for approx $3700. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1672 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17540 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 |
