Browse Forums Eco Living Re: How to reduce the maintenance of tank filters ? 2Jun 09, 2021 7:30 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to reduce the maintenance of tank filters ? 4Jun 16, 2021 9:41 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to reduce the maintenance of tank filters ? 6Jun 16, 2021 12:28 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to reduce the maintenance of tank filters ? 9May 08, 2022 4:27 pm Yes, I know.The filter screen has too shallow an angle and the larger aperture outside mesh is a failed design. The dominant market leader has mosquito proof outer mesh but its outer mesh also has the same shallow angle PLUS it also has a flat recess at the bottom that traps debris amongst other faults. The ICON Leaf and Debris Controller has a superior steeper outside filter screen but the unit is a conventional rain head shape and taller than the market leader and so everyone bought the inferior market leader because of the lesser head loss, the reason Bunnings ceased stocking the ICON unit. If you use the ICON diverter, you can 'reclaim' the head loss by replumbing the wet system pipe with a sediment trap and divert water directly into the tank via a low restriction inlet that also eliminates the head sapping vertical riser. I have linked the video below re your query in your other thread about pressure in a water column. https://www.youtube.com/watch?v=HlvHczb2vN4 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17956 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31908 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11301 |
