Browse Forums Eco Living Re: Cyclone watch and other meteorological interests. 21Sep 09, 2017 2:26 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 22Sep 10, 2017 3:58 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 23Sep 11, 2017 1:35 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 24Oct 11, 2017 5:23 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 25May 09, 2018 8:36 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 26Jul 17, 2018 3:39 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 27Feb 22, 2019 9:31 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 28Feb 23, 2019 9:45 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 29Feb 28, 2019 9:59 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 30Aug 07, 2019 12:20 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 31Aug 10, 2019 11:13 am The current time wind map shows the South Polar jet stream stretching over the Australian southern coast, bringing cold air and strong winds with it. The Americans refer to the jet stream as a polar vortex, something they and other northern regions now regularly experience due to Arctic warming causing the north polar jet stream to stretch and elongating southward. The Arctic has warmed much faster than Antarctica but warming in Antarctica is now happening at a rate not previously expected. The decreasing pressure gradient between the poles and the equator is also a reason why cyclones are becoming more powerful and making landfall further south. The Australian building codes and builders need to adapt to Australia's changing weather patterns now! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 32Nov 15, 2021 12:42 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 33May 30, 2022 11:28 am Current weather news reports warn of a "polar blast" bringing cold weather to southern Australia but what causes a "polar blast".. The screenshot below shows the South Polar Jet Stream has temporarily extended north far enough to reach over the southern Australian mainland. As Antarctica continues to warm, so too will the pressure gradient between Antarctica and the Equator continue to weaken which in turn will see the South Polar Jet Stream gradually extend more northward more frequently. Antarctica is bottom/centre in the screenshot. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 34May 30, 2022 11:39 am SaveH2O Current weather news reports warn of a "polar blast" bringing cold weather to southern Australia but what causes a "polar blast".. The screenshot below shows the South Polar Jet Stream has temporarily extended north far enough to reach over the southern Australian mainland. As Antarctica continues to warm, so too will the pressure gradient between Antarctica and the Equator continue to weaken which in turn will see the South Polar Jet Stream gradually extend more northward more frequently. Antarctica is bottom/centre in the screenshot. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So does that mean we will oscillate between really high temperatures and really low temperatures and nothing in between? Re: Cyclone watch and other meteorological interests. 35May 30, 2022 11:51 am Increasingly hot spells and cold snaps with strong winds as already predicted and realised but there will always be an "in between". The North Polar Jet Streams are a basket case now whereas the South Polar Jet Streams are still strong but weakening. As they weaken, they stretch and reach further north. Even an additional 100 km northern reach will have far reaching consequences for Australia. The northern hemisphere news outlets are more informative about changes in the Arctic than ours are about changes happening in Antarctica but the coming Arctic methane bomb will affect all. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 36Jun 07, 2022 9:58 am The South Polar Jet Stream acts as a fence to keep the Antarctic weather south. Successive northern loops are why much of Australia remains cold, wet and windy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 37Aug 05, 2022 5:19 am The cause of current strong winds. South Polar jet stream August 4 13:00 pm AEST. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 38Sep 26, 2022 9:36 am Our northerly neighbour the Philippines was hit last night by Super Typhoon NORU which currently sits off the east coast and heading WNW towards Vietnam. Super typhoon Nora is one of the most unusual massive storms ever seen due to its unprecedented sudden strengthening as it travelled east over hot water towards the Philippines and its capital Manila which escaped a direct hit by only 50 km. The huge concern now is the affect the large body of even hotter water directly between it and Vietnam will have on its strength, water as hot as 30.5C which is 2.4C above average. The purple in the screenshot below indicates this very hot water and the green circle is a 'click on' facility that can show everything from wave heights to ocean and land temperatures and even pollution in any chosen area. Just click Earth in the bottom left corner to bring up the box where you can then choose whatever you want to study. https://earth.nullschool.net/#current/o ... 758,15.989 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Cyclone watch and other meteorological interests. 39Nov 02, 2022 7:59 am South Polar jet stream shown looping over Adelaide and Victoria on 1 November 16:00 2022. This will become more regular in coming years as the South Polar - Equator pressure gradient continues to gradually weaken as Antarctica continues to warm. As the pressure gradient weakens, the South Polar jet stream will 'stretch' as the North Polar jet stream has done. Stretching is what causes the 'loops'. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6183 Hi there, We've just build a new hardwood (Greybox) deck and am wondering whether firepit protective mats/surfaces are sufficient? I'm not sure that they're heat… 0 2118 |
