Browse Forums Eco Living 1 Mar 09, 2015 6:27 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Floating water tank ! 2Mar 17, 2015 10:57 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Floating water tank ! 4Mar 17, 2015 8:26 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Floating water tank ! 7Mar 18, 2015 3:08 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Floating water tank ! 9Mar 20, 2015 10:11 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Floating water tank ! 11Mar 22, 2015 10:09 am The soil test indicated H1 soil for the slab, so there's clay there. I had a retaining wall on the garage side of house, but that ground like near the water tank was not compacted either. As well as the sleeper holding the 800mm high wall only went around 600 - 700 in to the ground (was only going to be 600 high initially). So basically I'm strongly leaning towards the idea that lack of compaction in those two areas is my problem, that will settle down more as I take care of general drainage/run off around the block. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17952 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 11292 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1949 |
