Browse Forums Eco Living Re: Help needed-north facing block 9Aug 22, 2014 11:16 pm Yeah, I was actually thinking the bedroom door near the hallway door may be a bit odd too. As it's a private area I don't think it would be too bad. Could extend the IT nook a bit, so the doors won't collide, that bedroom is 3.8 long, so you could loose a bit. Not sure if it's an advantage to have that door in the NE for cross ventilation or not. Really need to speak to an expert, gets a bit complicated with high pressure air where the winds coming from, & low pressure areas on the other side of the house. I think an average double bedroom is around 3.3 x 3.3m, so the master's definitely not large. But I think it should be ok, as you've got your WIR's. I think the WIR's are ok, but again, I'm no expert. No door on the ensuite? I see there's one on the toilet, but not the ensuite. Could have a cavity slider there if you wanted one I guess. Not sure about the AV, seems quite small. Guess it depends on what size TV you have. Don't want to sit too close to a large screen. Check on the Home Theatre & Automation forum. They'll be able to tell you the optimum viewing distance for different sized screens. The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18827 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 20293 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 23490 |
